Exhaust leak, and which gaskets?
Hemogoblin
I replaced my muffler recently and I noticed on start up that there is a leak (visually could see water dripping and you could hear the leak under the truck) at what I can assume is a donut gasket and possibly further up, at the flange coming off of the right manifold. In the picture attached, it would be where the number 2 and 3 are located. I think I have found the gaskets for #3 (I am going to replace the drivers and passengers side together - Fel-Pro 61240 and 61710) but anyone have any info on the gasket at the #2 location? I am assuming it's a donut? It isn't even listed on the Mopar website. Actually, none of these are.
Any help would be appreciated. Thanks
Threesuns1
Northeastern Maryland
Several members have had broken flange bolt (#17 & #5). Actually, it is a bolt and threaded flange, most are drilling out the flange and using a bolt and nut to repair it. Do a search for broken flange bolt if you would like more info.
