exhaust ID
1791
i found these locally i replaced my muffler on my last truck with a flowmaster it was ok but i don't want to do it again.
i found both of these locally the first pic is the type was on my truck. the second is a factory but not the same is it a GT exhaust. 500 with the cats is a deal. if it's a GT i'll get it
549813673_1337144324606129_488998714018875041_n.jpg489371517_1048129823458693_3711367709154445258_n.jpg
Check the stamping on the muffler to confirm. Should be stamped C-9396 if it’s the GT exhaust. Standard more common exhaust is stamped C-9367. The GT and standard exhaust look identical physically.
GT resonators will be stamped with C-9048-L and C-9048-R
GT muffler will be stamped with C-9396
The standard resonators will be stamped with C-9304-L and C-9304-R
The standard (quieter) muffler will be stamped with C-9367
thanks. in one of the pics the muffler actually has 2 pipe's coming out and look's more like glass pack's on the rear i was thinking that was "GT". the other splits with a Y after the muffler and has cans at the rear. turns out that could be a GT exhaust depending on the part number.
upon closer inspection one has a few clamps and is even clamped off the cats look's like some kind of a cat-back could be the mopar performance or something else. i think it's off a classic.
i'll get more details off the stock looking one it came off a 23 limited longhorn it's 250 if that turns out to be a GT that would be a good find
That second may be a Mopar exhaust, definitely not a factory GT setup. I bet it sounds decent tho.
