ETorque
b.courtney001
I have a 2019 ram 1500. How do I know if I have an etorque engine
Pop the hood and look at the engine... does it have an alternator or a giant electric motor mounted to the upper driver side of the motor. It’s insanely obvious so if you can’t tel then it’s not there.
Etorque Hemi-
Standard Hemi-
Etorque Hemi-
Standard Hemi-
If you do not want to open the hood, if you pull up to a stoplight and your Ram shuts off until you hit the gas or take your foot off the brake causing you concern over the eerie silence and pissing you off when it is 100 degrees outside because the A/C stops blowing any cold air whatsoever..... you have eTorque.
