Etorque serpentine belt replacement
longhorn4461
I am having the hardest time figuring out how 2 get enough tension off of pulley to put serpentine belt on.. Does anyone know how to get the lower belt tensioner to move. Tried to use bracker bar, but no movment.
This should help i have some more files if this doesnt help
Thank you so much for providing those snapshots, I was able to finally replace the belt. Had to remove strike plate bracket, Then reinstall bracket at the end of procedure. I would not have known to remove bracket first without your pictures. Thank you
Your welcome glad i could help !
I’m having this same issue, I removed the bracket and moved the tensioner over and put a pin in to hold it. My issue is that I cannot get the hydraulic tensioner to move at all. Is there a step I’m missing?
