Electrical Grimlins
Motorbreath87
Labrador
This is my first post and unfortunately it's not a good one.
Just bought my 2022 1500 Longhorn last month and it was good going until last week.
I was driving down the road in heavy rain and every light and warning in the dash came on.. One message was to service the gear selector. I have a video I'll attach as well. I hooked up a code reader and I had 3 different codes showing.
U0402, u0001, and u0422.
So I cleared them and started the truck and it was all good, nothing came back right away so I shut the truck off and left it for 2 days. When I went to start it yesterday she wouldn't even attempt to start.
What is weird, is that key fob doesn't work to unlock or lock the doors. But when you sit in the truck it says "press brake and start button" but you can't even change the ignition from off to Acc or Run. Also, I was sat in the truck last night just reading forums and the message came up on the screen to press the brake and start button.. but then I realized I had left the keys in my house. I'm not sure why that message would pop up while the keys aren't anywhere near the truck.
I charged the battery overnight, before I left home this morning I checked to see if the key fob would unlock or lock the doors but still nothing.
The only other thing to note is that the dome lights in the front of the cab did not work with the doors open. So I had taken it down to check the bulbs, only to find the clips broken off like someone tried to take it down and didn't know what they were doing. Also, while I was sitting in the truck reading I noticed the sound system kind of popping.. there isn't any music playing, it sounds like something back feeding the entertainment system. When she makes the popping sound the yellow automatic start symbol in the dash very quickly blinks. I've noticed this popping noise since I bought the truck.
I'm 6 hours from a dealer, so any help you can offer would be appreciated.
I couldn't upload the video, so I put it on YouTube.
Jedi9
There is a lot of information about cab leaks around the rear window (the frame will crack) the shark fin antenna, and the 3rd brake light. Water will run down the inside of the cab behind the rear seat where the rf hub (for the fob) and also the battery for e torque if you have it. I recommend taking a look behind the rear seat for water
bullitt_60
Atlanta, GA
My recommendation is to change the battery. Even if appears as if it is holding voltage, I'd still replace it. In previous Rams I would get one warning such as a strange code or gauges go haywire and the following day it won't even turn over.
Motorbreath87
Labrador
No water found. The frame of the window has a very slight hairline crack.
I'm currently at work and I'm shooting ideas to my wife at home.. So she removed a couple relays for 20 mins or so, put them back in.. and the truck started!
bigdodge
Happy Ram Owner
did you buy from a ram dealer or somewhere else?
Ellisstrong
Atlanta Ga area
I would also recommend hooking your battery up to a charger/maintainer to make sure it’s fully charged if you did switch out to a new one
kapinallinen2
5thGenRams Supporter
Southern Maryland.
U0001.
CAN C bus.
Possible Causes:
OPEN OR SHORTED CAN C BUS CIRCUIT
OPEN OR SHORTED CAN C A/T BUS CIRCUIT
CAN C RELATED MODULE
CAN C RELATED STAR CONNECTOR
SECURITY GATEWAY MODULE (SGW)
A good possibility of water damage to the RF hub and it taking down the bus.
I would look for signs of corrosion on the connectors and the PCB.
