edit
Lungs414
Apologies I think I posted originally in wrong section.
What pads and rotors did you use? Use any grease on the backside of the pads? Sometimes they just need to seat properly before the squealing goes away
Power stop and yes did wire wheeled behind the new rotors and cleaned a greased where appropriate. Slide pins, behind pads, new hardware. I disconnected the negative for a minute then reconnected. It seems ok now but I have to wait to see if it locks up again overnight.
Thanks
