Malodave
I just printed Some Dust Caps for my 2021 EcoDiesel. I used a Gray
ABS like Resin. I still need to sand the top, paint it green, then color
fill the Lettering. There is space to install a screw in Magnet. It uses
a 4mm X 37mm O-ring to seal. This requires you to remove the top
1/4" or so of the internal ribs on the Filler Neck. Will update Post
after Finishing is complete.
Malodave
Malodave
