Easiest way to get a 12 volt outlet in the back seat?
philodog
It is so disappointing that there is no 12V outlet in the back seat. What would be the easiest way to tap into the trucks 12 volt back there? I don't want to run extensions from the outlet up on the dash. The 110 outlet back there is a cheap modified sine wave inverter that will fry any converters.
Installed cigarette lighter outlet and USB outlet into the little cubby hole.
Ran fused 12 volts from the battery, thru firewall and under/next to the center console.
