E TORQUE was a big mistake.
I had read on forums that the start stop feature was hell on the eTorque motor. Although you can turn that feature off, you have to do it with every start , which most people forget to do. I purchased a module for $100.00 that permanently disables the start stop. I hope this will help avoid eTorque issues.
Yep have my start stop off 99% of the time with the Tazer hope it helps also.
There is a thread here that is all about doing the bearings yourself if that is what the problem is. If the unit puked, it's a new one.
It’s not really a big deal. I bought a 2019 first year 5th gen Rebel in Oct 2018. It was one of the first Rebels available in town at the time. No issues with ET at all after seven years. I probably won’t would have taken a non ET if available but not tripping about what may go wrong. Still Love this truck.
Good looking truck !!! Dog's look cute also.
without stop start you basically totally disable the e-t system and it provides no benefit, not that it had much in the first place.
That’s actually not accurate. S/S is only one feature. Other benefits…we can debate if they are useful or not, sure. But S/S is only one feature of e-t.
Plenty of videos and documentation about its other features. Again, not arguing if they’re useful/beneficial, that’s personal opinion.
Just to name a few.
Extra 100 plus lb ft of torque for the first half rotation of the tires.
Smoother shifts between gears.
Regenerative braking does increase pad/rotor/overall brake life.
If you want to debate if that’s 1% or 50%…I’m with you…but to say disabling S/S is basically disabling the E-T system is not accurate.
Just to name a few.
point taken, smoother shifts is interesting because i think it's already to smooth lol. i loved barking gears on demand but that don't happen anymore.
Just to name a few.
I actually thought the same thing..disabling the s/s basically took the whole etorque system out of play. Is that not the case?
More than fair. My comparison is three prior rams, all Hemi, 06, 08, and a 15.
I went 3:21 in my 2023 cause I really don’t tow too much anymore.. if anything, I don’t feel a slight dip going from gear to gear.
I 100% can tell… regenerative braking. Going from car to car… big difference slowing down.
I do notice much better gas mileage overall, tank per tank, between my 15 Limited with 3:92 and my current 23 Limited with e-t and 3:21. Do I save a few RPMs when cruising? Of course. Does it save a little stop/start, yes.
I haven’t had an etorque issue to date, so of course I’m good with it.
Could my tune change should I have an issue. Like anything else, very possible… and yes, I’m knocking on wood :)
