E Torque ...help !!
ttabs
2019 Ram 1500 3.6L >>>>I had a water pump replacement done and since then I have a Screech or chirp on acceleration / deceleration... Also start/stop not functioning properly .. I have been told that e-torque needs a hose because it has no coolant ... I see the e torque has a dedicated cooling system not connected to engine/ radiator coolant ???? I that right ??? if so, How and where does it get filled ???
replaced 2 tensioners .... belt .... and pump ......I think mechanic has no clue !!! please help if you can.....can someone explain all this ?? thanks in advance
