E locker vs fluid friction modifier
x0infinityx
2022 ram 1500 hemi etorque.
Off road package 4x4. 3.92 ratio.
About to change every fluid in the truck. Came across the front/rear/transfer fluids.
Question:
someone said I needed to add a "friction modifier" to one of those but wasn't sure which one (or if multiple).
Since I have an e-locker 4x4, with 3.92 gear ratio. Do I need to add this "friction modifier"? And if so to which areas (front/rear/transfer case).
Any other info im overlooking much appreciated.
I did not add the friction modifier to mine when I changed at 50k. No issues. That's mainly for the limited slip differentials.
Question:
You do not need the additive for the e-locker
