MrBTeachUs
- Jan 5, 2023
I have a 2020 RAM 1500 Laramie with 72,000 miles. Recently it started having incorrect DTE and fuel gauge readings.
I believe it is the fuel level sensor, but would like to confirm before dropping the tank to replace.
What I'm seeing is inconsistent DTE and fuel level readings when I fill up and as it consumes fuel. Sometimes I'll fill up and it's fine. The next time it may show only 3/4 full and DTE matches that reading.
When it does that I can drive for a while and it might go up but not always.
If it's not the fuel level sensor I was thinking it would be the gauge cluster. I'm assuming the DTE gets the fuel level from the fuel level sensor and not from the fuel gauge, but I'm not sure.
Any help would be appreciated!
Thank you!
Thank you!
