DTC Code U0010 Medium Speed CAN Comm Bus
BIGDCOBIA
So my superchhip handheld is telling me I have this DTC code. (DTC Code U0010 Medium Speed CAN Comm Bus) Every time I try to clear it comes right back. No engine light or anything and I don't think I notice any difference in performance but how do I get rid of this code?
I would talk to Superchips... it could very well be their module causing the issue
^^^^^^^^^^^^ Ditto... If the code is in the permanent section , it may take dealer to clear it and/or problem go away and after xxx amount of recycles code clears.
I also had a pedal commander installed and I think that may have caused the problem. I took it out then used the superchip to clear codes but still doesn’t go away. From what I read issue with voltage and pedal commander so might be the culprit
I also had a pedal commander installed and I think that may have caused the problem. I took it out then used the superchip to clear codes but still doesn’t go away. From what I read issue with voltage and pedal commander so might be the culprit...I went into limp mode several times until I reset with Superchips....over last several months ...superchips no throttle boost miss that already but sick of dealing with issue weekly
