Driver's side brake light out
brazzledazzle
Hello all. First time really asking a question here about the pickup. I have a 21 Laramie with the LED+blind spot brake light assembly with the top brake light not working. Everything else works on it. I'm curious if just bulbs are replaceable or if this is one of those whole assembly jobs. Picture pointing to the brake light that won't light up. Thanks in advance.
It's an assembly. Need to replace full light. I don't know of any companies that can fix them.
You can hit up Jeremey and see if he does.
Yeah I figured this was the case. What an idiotic way to do business. Instead of replacing a $19 light, let's spend a couple hundred on the assembly.
Honestly, LED are a better way to go and are supposed to last longer, but low quality doesn't help. I'm not sure how common this problem really is. I think I've only seen a few times.
