Drivers door wind noise
Nightowl
I get wind noise in the upper corner when driving on windy days or highway. If I pull in on the top of the door it goes away. The door is closing all the way and the seals look good. Any ideas on a fix?ramwindow.jpg
Perhaps adjust the hinges and striker slightly. Anything look misaligned as far as the door fitment goes?
Nothing looks misaligned. I found a youtube video where someone adjusted the striker. It was a older ram. I tried to adjust mine but it didn't have any play in it.
In the old days we would peel back the weather strip from the framework, take a chunk of 2x4 and a large hammer, and coax the lip edges toward the door. Sounds nuts, but it worked. Equally questionable, a large man could grab the window frame of the door and with a knee against the door and the window in the down position, physically pull the window frame of the door inwards a bit.
Ahhh - those were the days !!
