canadamess
- Nov 7, 2024
I have a 2022 Ram 1500 Bighorn. The problem I am having is that when I start the truck in under 40 degree temps, the driver heated seat does not come on while all the other functions do. What I discovered in going into the UConnect where it shows the heated seat icon selections, if I press the driver one it turns on the passenger seat, and if I hit the passenger seat it turns on the driver seat. The actual hard heated seat buttons work correctly. I believe this may be the reason for the driver seat not coming on with starting the truck. Any idea why this may be or if there is a setting in the BCM that I would need to change to correct this? I have the alphaobd app. I also just replaced the battery recently. Any help or suggestions would be great. Thank you.
