That short piece is called a slip yoke, and it's made to slide in and out a little. When the rear suspension is compressed, the driveshaft pushes it in. When the rear axle drops, the driveshaft pulls out. If you lift the truck too much, you need a longer driveshaft or the slip yoke can pull out at the wrong time.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
