jrladd
- Nov 12, 2022
Has anyone successfully tapped in to the 48V circuit for the Etorque to draw power from? I've heard the generator/starter puts out around 3KW at 48V. This would make charging a portable power station (Eco Flow, Jackery, etc.) much faster than a 12v system. For instance Eco Flow sells an alternator adapter that essentially is a DC - DC charger for $600. It steps the DC up to 48-53V to fast charge the battery. Could we not do the same with a direct connection to the leads on the 48V battery at the rear cab wall?
