Door stickers missing
PARAM2019
My 2020 Ecodiesel RAM is missing the door stickers I knew it had an accident before my purchase and now I know where it was 😒
How can I find the tire pressure information?
Scram1500
I'd check the manual for specifics, my door jamb says 36 psi for 275/55 r20. Might be different based on rim size
Jako
Borough of Parks
PARAM2019
Thanks Scram That’s the size of my rims. Would you vary from the 36 for towing a 5k camper?
Brutal_HO
The Mad Irishman
Douglas County, CO
FWIW the sticker on door jamb is just a reference for the factory installed tires. If you have replaced tires, then it won't be accurate. You need to do a chalk test or monitor tread wear and adjust to find the correct pressure for your current set up. As for towing a trailer, it will depend on the load on the tires and their load rating. Always increase pressure in rear tires when towing to match the load you are towing. Once again it will vary based on load.
Scram1500
I'd air up. If you're on OEM tires with the standard load rating 45 psi or so will be your max cold pressure
scottmoyer
If you replace tires with different load ranges or even size, what happens with the TPMS notification? I have the factory tires for my Rebel with 55 psi front and 45 psi rear. If I replace the tires, how do I get the dashboard notification to not alert on different air pressures?
wills446
You can reprogram the TPMS alerts if you have something like an AlfaOBD or TaserDT. I personally used a TazerDT to change the alert pressures on my truck.
