If it is a leak, what can be done to fix it?Looks like it has a small leak on the right side of this picture. that black soot coming out at the bottom has me question it.
ThisLooks like it has a small leak on the right side of this picture. that black soot coming out at the bottom has me question it.
If the resonators are what's right before the exhaust tips, then they are still on there. It's louder than my next door neighbors stock exhaust on his '21 Limited, but it's not going to wake him up when I crank it.That’s a magnaflow muffler and what ever shop welded it on didn’t do a very good job. If it’s loud they may have removed the resonators before your tips as well
Sounds like my stock 21 prior to the Borla S. My 21 doesn't have the front resonator though.I am the second owner, so I don't know if the previous guy had work done on it. I've looked underneath the truck and it looks stock, but I may not be looking in the right places.
I think it sounds pretty good too for just a $120 or so muffler. It's just how I like it... a good throaty growl when I want it to and no drone on the highway.2019, 2020 trucks I think are the only ones with the pre-muffler resonator. The later trucks should only have the two "muffler looking" resonators before the tips.
Sounds pretty good to me, the welding doesn't look bad, but you do have a small leak as noted, any muffler shop can touch that up for a few bucks, have them run it and they can do a quick check to make sure there aren't anymore leaks.
I have a friend with a Bendpak lift and a Lincoln welding machine in his shop. He offered to fix it for me.
Yes, I am pleased with it. Like I said, previous owner did it and I didn't even know until yesterday that it had an aftermarket muffler.Nice, I think with that fix you should be pretty happy with your setup. I did something similar on my truck, I had the muffler replaced with a Flowmaster Outlaw, essentially the most aggressive muffler they have outside of a straight pipe. However, with my 3 resonators, it sounds perfect to me. No drone when cruising, but a nice 60's muscle car sound when on the pedal. Yours sounds not that dissimilar to mine on idle.
When cruising and MDS operating, do you hear any drone? If so, that's pretty normal for most aftermarket mufflers when the truck is in 4-cylinder ECO/MDS mode.
Yes, when MDS kicks in it does drone. When MDS turns off and the other 4 cylinders wake up, it makes a brrrp sound. I don't like the way MDS drones like that, so I always hit the gear limit button when I put it in gear.
