Do bullrings Rattle?
thomasshawn
2022 1500 limited . Considering adding flush mount front and rear bullrings. Saw a few complaints that they rattled and so people were removing them. Since you have to carve up the OEM plastic cover, I don't see removing them as a viable in once installed.
Do they rattle and people just deal with it ? Or is it really not an issue?
Put loctite on the screws and you should be good. I heard mine whenever I hit a bump, and it's because the screws loosened up and the clamps were swinging back and forth.
No rattles here. Mine came with lock washers. No screws loosening up. Also the rings snap in the down or up position. Maybe they did not snap them in?
