Ditching tow mirrors on 2026 Tungsten
James1414d
Portland Or
I hate these mirrors! I wonder if the standard mirrors would be plug/play? I did try to search the forums, but didnt come up with much for the 25-26 models. Any clue?
This has been discussed many times. Doesn’t matter that it’s a 25/26 or not. All that changes is what mirrors you swap in.
Yes it can be done. But you need to make sure you find th same level of tech in the standard mirror. So 360 can and heating etc.
The tricky part however is coding for the 360 camera to be calibrated. Dealer will have to do it.
Also keep in mind you will lose the feature where the side blind spot camera activates when you put the turn signal on.
