Ted wilson
- Feb 18, 2023
I had a ram diesel that got totaled. It had 4/4 tank of diesel. I hooked up a 1/2 hose to the pump and opened the drain. I put the other end into a new 2500 and did not notice any resistance as i put the tube into the filler.
After i transferred the diesel i tried to pull the tubing and it was stuck. It looks like there is a lever or something that will not let me get the tubing out.
I tried pulling hard.
I sharpened a 3/8 rod down to a wedge. And got it between the tube and the metal disk just a little.
No luck.
Any recommendations?
I could cut the tubing and shoved it onto the tank. The piece is probably going to be 3-4 inches long which i do not think will inyergerr woth tne pump.
Any other recommendations?
No luck.
