DEF injector error 2048.
Code 101
Irritated, unable to determine the problem with DEF injector on a 2018 diesel . Took out old injector and cleaned and tested (12.3 OHMS). Which is believed to be within range. Decided to buy and after market and installed but to no avail it still has the error code
1. Is there a difference/ problem with using the aftermarket?
2. Should I dig a little deeper and take off the heated supply line between the tank and the injector to see it’s plugged ?
any suggestions of advice appreciated
