Deactivating horn after locking
TruckRamRod
Hi,
Does anyone know if it is possible to deactivate the horn chirp when you lock the doors either by the key fob or the button on the handle? I get home late at night and would like to be able to lock my doors with the fob but not wake up my neighbours. Thanks
Not sure if there is a way just with the FOB. However, which Uconnect Radio do you have? If you have the 8.4" setup you can disable the horn beep by going into your SETTINGS --> DOORS & LOCKS --> SOUND HORN WITH LOCK
I have the 12 inch, but it has the same options. Got it all set up for 2 presses for horn beep now. Thanks you very much for the help.
