Dash leather shrinkage diy fix
uhhhh
Hello, new member here.
I recently got a 2019 Limited with the black interior and today while giving it a deeper look through, I noticed the leather was giving away on cluster cover. I popped it off and did some research and saw that it was a mildly commonish issue but offered no fixes besides attempting to replace the entire dash through a dealership. Clearly not an option, I kept searching and came across helpful info on a Lamborghini forum.
I soaked a towel and laid it over it for a couple hours while pulling on it periodically and it stretched with ease. I used some clamps and strips of leather so it wouldn't mar the surface to and let it sit to dry and shape. Threw in some contact cement and it seems to be doing the job very well. Hopefully if anyone else has this issue, it helps. 1000037886.jpg
How did you take the cluster cover off??
Does it just Pop off??
Yes, just life at one of the front corners, and then slowly work your way around towards the back around to the other side. Once that's up, just reach under throught the front and give it some leverage and it'll pop off.
