D/S Front Door Glass Hesitation
natev-safelite
2019 Ram pickup 1500 4 door quad cab had the front driver side window replaced the other day and the auto up and auto down both work fine, but if you try to manually roll it up, the window will stop at some point and you have to release the switch and go again to finish it.
The front passenger side window is doing it as well but was not replaced.
Any thoughts on why this happens?
I would try calibrating both front windows.
Sent from my SM-G998U using Tapatalk
