Ram20Limited
- Aug 2, 2024
Hi
I have a 2020 1500 Limited.
Two things going on - first is the rear window leaks slightly in the car wash. I have an extended warranty hoping to get it covered under. What piece typically fails that causes the leak? There is an exclusion in my warranty for interior and exterior trim and molding that I'm worried they will try to refute under.
Second is a message periodically popping up "Service Active Tuned Mass Module". It leaves no code or stored message and nothing is noticeably going on with the truck. Any ideas here what this is and how to guide the shop to fix it with warranty?
Thanks!
Thanks!
