Core4x4 control arms
stevieb92
Hey all, I just wanted to give a shout out to Core4x4 for their superb support. About a month ago, I ordered rear control arms (upper and lower adjustable town series) for my 2024 Rebel and went to install them a couple weeks ago. It turns out the upper arms were about 1/4 inch too long to match the OEM arms even adjusted as short as they would go. For the moment to get it put back together I installed the lower arms longer by the same amount so the pinion angle was correct. I got in contact with Core4x4 and explained the situation. After emailing pictures and some measurements I had a new set of upper arms (minus the adjustable joint). The new ones were perfectly sized and install went smoothly. Major kudos to Trevor and the crew at Core4x4 for correcting the issue without any hassle in about a week.
