Cooper DISCOVERER AT3 4S 275/60R20 on a Limited
Going with the same tire on my Limited but can only find tire with OWL. Anyone know if they make without the white lettering?
I think they should deliver it just like that:
I'm so glad you posted this. I have the identical truck and wondered what the 60's would look like. I was hoping they wouldn't look off or out of place in the 'normal' suspension mode.
Is your suspension set at 'normal' in those pics or 'offroad'?
Also, you're now going 73 when your speedometer says 70 and your gas milage just took a 1.5MPG hit.
*EDIT*
I see you're in Saudi Arabia so I apologize for assuming you use miles vs. kilometers.
You're speedometer will be almost 4% off and your gas mileage will drop by about 10-15% :)
*EDIT*
Thanks for those additions :)
Yes, the truck was sat on Normal mode.
Choose those Cooper's specifically as they have a mild tread compared to some others like KO2's, Wranglers, etc. Didn't like an aggressive tread and sidewall on a Limited at all.
  • Like
Reactions: Buz
Just mounted a set of these today on my Big Horn Crew Cab 4x4.
Pictures do not do it justice. I was going to go with a 34” tire but I did not want an LT tire and this looks better than I thought it would. IMO you lose nothing compared to the OEM Bridgestones. Better looks, better handling, better performance all around,etc.
Also recalibrated the speedometer with Alfaobd.
Before:
After:
Still need to level it. Bilstein 5160s installed in the back, 6112s going in the front.
Very nice - I am looking at falken wildpeak AT3W in same size for my limited.
out of curiosity, what do you do for a living over seas? Nice truck and mustang! I have been looking at some 10 speed 2019+ for a twin turbo setup.
100%.
I am a citizen who works in the Telecommunication field for a major multinational company.
And yes, we do have a lot of Americans works in Oil, Tele, consultancy, military, education, and a lot of others.
And for that 10 speed mustang, I would say go for it you will have wonderful times :)
Same size but also leveled.
Before:
After:
What tire and size are those tires?
Before:
After:
Did you also use wheel spacers? Looks like it has a lil bit of poke? Maybe it's just the pic?
Welp, your truck looks D$M& good! I have now decided on tire size thanks to your pic. But truck is already reverse leveled, so it should look good.
just got the Cooper AT3 4S's on my truck today..... the stock tires just don't cut it in the winter, 2022 Sport, no lift / level, 275/60/20 AT3 4S no rub so far... granted they just got put on and it's snowing like a mofo so i didn't really get in there and double check, no audible rub noises in any parking lots, don't put enough miles on the truck to warrant seperate summers vs winters so after researching abunch i also landed on the Cooper's, already a night and day difference... the Bridgestone's slip and slide pretty steadily, the Cooper's grab the snow so much better..
How's the ride quality on these compared to stock? I imagine a little better with the larger sidewall. I'm debating tire options for when I upgrade my wheels in the Spring.
ride quality is as close to stock as you are going to get out of an AT tire that is very good in all conditions , it's not an E rated so not overly rough at all, with very little addtional road noise, def a nice addition especially in area's that get severe weather, it snowed 35cm in 24 hours here and they gripped 10x better then the Duellers, can't see it doing poorly in any real world environment, certainly not a mudding tire, but FSR's / winter / highway / trail / all around duty tire for as close to stock feel as possible they are great.
Solid advice. Thanks! These are the top of my list so far.
Before:
After:
Thanks for the pics! That is a sweet looking truck and really like the Night Editions. Just ordered the Cooper AT3 4s to go along with Rough Country leveling struts. Your pics sure helped me verify I will be good with this decision!
Before:
After:
What size are those tires?
Before:
After:
What size are those tires? Are those 275/60r20’s?
