Coolant leak. 2019 1500 3.6 V6
jdykstra
The coolant is dripping from the bottom of the engine, under the bolt in the picture. Not sure if it’s originated from this spot but it doesn’t appear to be any coolant above here. What is this bolt location? There is a coolant hose right above it
Have it pressure tested to confirm , but it's most likely the water pump. Skip the aftermarket junk and get a Mopar one, otherwise you'll be replacing it again in 8-12 months.
Sent from my Pixel 9 Pro using Tapatalk
  • Like
Reactions: c3k
