Control Arms and Axles Torque Help
msnyder1112
Massillon, Ohio
I'm preparing to replace control arms/axles and sway bar links in my 2019 4wd big horn. I've been struggling with finding torque specs so if someone could be so kind and confirm these are correct, that would be awesome.
Axle - 185ft/lbs
LCA - 155ft/lbs
LCA BJ - 38ft/lbs + 90degrees
UCA - 130ft/lbs
UCA BJ - 40ft/lbs + 180degrees
Swaybar Endlinks at Control Arm - 75ft/lbs
Swarbar Endlinks at Bar - 20ft/lbs
Lower Shock - 125ft/lbs
Outter Tie rod - 22ft + 90degrees
Brake Caliper - 31ft/lbs
