Constant USB error message
WXman
Kentucky, USA
So I have a wireless phone charging pad plugged in to the USB port. The Uconnect screen flashes a little square dialog box with a USB error message approximately every 5 seconds. Does anybody know how to turn this off or or cure it? It's rather annoying.
I think the truck is looking for a smart device on the other end of the USB cord but all I want to do is charge my phone wirelessly without error messages.
It might be trying to pull too much juice and that's why it's throwing errors.
Have you tried the USB port in your center console? Those are generally not "media" ports.
You also might have an AC inverter plug right under that? Could use a regular charger plug too.
Nope, this truck is *supposed* to have the AC plug under there, but it was apparently deleted by Stellantis and shown on my window sticker as a $40 credit. Very annoying, as I do love having A/C power in my trucks.
I will try routing the cord to the console and try that. Thanks.
I had to dumb down my charging pad. Truck didn’t like the rapid from the USB port
I plugged it into the USB port in the console and problem is solved. Eventually I want to run an A/C inverter, but for now this works. Thanks.
Was the AC outlet removed from the rear of the center console also?? that sucks! the inverter is rather handy.
Yep they deleted all the outlets and inverter. I don't know if the wiring harness is there or not, haven't looked. But for the cost of retrofitting factory parts I could just install an aftermarket inverter and have 2,000 watts instead of 400.
It's a bad time to order a truck. You never know what equipment is and isn't going to be on it when it shows up.
I think the only thing that got deleted on mine was the Active Air Dam.
Nothing got deleted from my truck.
Probably because I ordered a Limited fully loaded except for trailer brake.
I think Limiteds got special treatment at the factory.
There is a fried transistor in the media center plugin circuit board, and the media module need to be replaced.
The part number for my fully loaded 2021 Rebel was 68397098AE. I got from Nismopar.com on Ebay, it cost $100, and I confirmed with the seller that the actual part he was selling ended in "AE" and not one of the previous versions...AB, AC or AD.
To install it:
Remove all four square plastic covers at the lower corners of front and rear sides of the console - you will have to move the seats back and forth in order to get access to all four.
Remove the 2 "boomerang" shaped trim covers from each side of the dash, these frame the top front corners of the console, and are removed by pulling them straight out towards the back of the truck.
Now that the covers and trim is removed, removed the 6 10mm bolts and side the console back toward the rear of the truck. with the left side rear seat folded up, you will get around 1 foot of room that allows easy access to the console area that houses the media plugin module.
Unplug the 3 plugins by squeezing the wire release tabs that you will feel on the bottom (not visible) wire plugins.
Plug the new Media Module into the 3 wire plugins, and verify that the new module corrected the problem - I bet it does.
The old modules slide out of the back of the console housing, towrads the dash. To remove the old module from the console, there are 4 tabs, 2 on the the top and 2 on the bottom. In order to depress the 2 upper tabs I slid 2 tiny screw drivers between each of the console media center housing and media module, then I blindly reached under the media module and felt for the 2 hidden bottom tabs, pressed them in with my fingers, and the old module popped right out.
To reinstall the console, slide it back into place - there are 2 large alignment pins at the front that slide into metal holes in the dash - install the 6 bolts, tightening the 2 at the dash first, tighten the other 4, reinstall the square plastic trim covers, and snap in the 2 "boomerang" trim pieces and you're done.
It took me 20 minutes from start to finish, yes I have had a lot of mechanical experience, but this is an easy repair and the only difference between me and you is it might take you longer.
The local Ram dealer wanted $800, including the diagnostic.
Sounds like the USB port is trying to “handshake” with the pad like it’s a data device instead of just power. A quick fix is to use a simple 12V adapter in the cigarette lighter instead of the truck’s USB – that way it just gives power and won’t keep looking for data.
