Connecting reversing LED light on my 2022 Longhorn.
con-cept
Hi Guys,
After lying under the truck to figure out where I can safely take power for connecting an extra reversing light bar, I still have no clue.
I found the harness for connecting a trailer but mine is converted for Europe to a thirteen pin connector (see attached picture).
I suppose there is one wire on the original harness that gives power when you put the truck in reverse? I tried to messure wich wire gives voltage by putting the truck in reverse but there is no way to put the truck in reverse while not actually driving it.
I also found on the driver rear side near a main connector a small connector (see other picture) that is not used. What is this for?
Anyone can explain or has a wire diagram?
One more note: the LED bar consumes 4,5 amps.
