Confused
skeith223
Hi all I was wondering if anyone out there can help me with a situation that I’m having I purchased a undercover ultra flex bed cover for my 2024 Ram 1500 5.7 bed with ram boxes, I also have black rails installed from the factory. I was told that this cover would work on this truck if I remove the black rails and bolt in the rails from the undercover using the truck hardware, problem is there are no holes in the undercover rails so I’m wondering if they sent the wrong rails or am I missing something. Any help would be appreciated. Thx
I don't know about that cover buy 99.99% of covers will NOT work with Ramboxes with black rails.
You need to remove the black rails and install silver rails.
It sounds like they maybe didn't send you the correct rails for Ramboxes, as I see some reviews and pictures and they don't have silver rails.
You will need Silver rails to Mahe the bed cover work. Typically I believe you get black rails from the factory if your truck came with oem bed cover from the factory.
Sent from my SM-S918U1 using Tapatalk
^^This. Swap out the black rails for silver.
