Column shifter replacement
Gmanuelg1
Hello, I have a question regarding a shifter upgrade. To install a leather limited style shifter, do I need to remove only one bolt and slide out the existing unit, or is the replacement process more involved? It’s a ‘23 2500. Thanks.
Since this forum is for 5th gen 1500's, and none of these trucks uses a column shifter, it's not likely you'll see a lot of responses on this question. You might have better luck posting this question in a forum for HD Ram trucks. There is one here but it receives little traffic.
I only suggest this because of the lack of HD traffic here, but there are other forums out there with much better HD support.
