Cold start squealing noise
Jebco252
Has any one had a cold start squealing noise that lasts only a second or two , my truck is a 2025 Big horn only 600 miles, sounds like a belt and never happens when warmed up. I am going to the dealer on Monday just thought I would ask if anyone else had this issue
Yes, mine last 5-10 seconds but only when temps outside are cold, under 30F. Still not sure what it is. Only happens on first start of the day.
Yes, I have a 2025 1500 Ram 3.6 cold start squealing from 10 to 30 seconds. It's been in the Ram dealer shop twice and they can't seem to figure it out.
Glazed belt or not enough tension... which will glaze the belt
Yes mine started doing it a few hundred miles after getting it. Only for about 10 seconds on cold mornings under 30 degrees then stops to never be heard the rest of the day. Sounds like a tensioner whine when happening. I read it's normal on start up cold weather but if it continued while driving then there's a problem
What did the dealer say about the noise. I have the same truck
I had this in my 2012 Jeep GC with the 3.6, dealer first replaced the belt itself and then later on replaced the idler pulley. There was a tsb for it, 07-002-15.
