Code p2138 after MDS delete
Whyjustwhy
hello everyone
i'm wondering if anyone has come across this issue or might have any suggestions. After tracing down many electrical issues with my 2019 ram 1500. I have finally gotten down to a P2138 code indicating improper voltage reading from the accelerator pedal sensor. Just for grins and because it was super easy and fairly inexpensive I went ahead and replaced the pedal and that is not the issue.
For a little backstory this all happened shortly after doing an MDS delete on the truck. There were a multitude of electrical codes that came up but after figuring out we had a bad PCM we replaced that and all the codes except this one went away. I'm kind of thinking something is at least partially grounded out or there's a can bus problem. I ordered an oscilloscope so I can check the canvas signal. One thing that really puzzles me is the P2138 is very intermittent as far as how long it takes to cause a throttle problem but it happens 99.9% of the time. Sometimes it will happen within minutes of starting the truck and other times it will take an hour or two or even longer to show up. When I turn the truck off and back on again the code resets or at least the accelerator works for a time.
