Clunk in wet conditions
KevInSD
South Dakota
Hi guys. My 2019 BigHorn (133,000 miles) has started making a clunk noise in the front end upon acceleration and I cannot figure out what it might be. The problem is that it has only been happening when it is wet out. In dry conditions it will happen once in awhile but the other day when it rained most of the day it was happening the whole time. Once the rain stopped and it dried out the noise went away.
The noise happens when I start accelerating at slow speeds and will sometimes happen when I’m slowing down. It almost seems like the driveshaft when it engages but I have no idea if that would be the issue. Have any of you guys had an experience like this?
Check your sway bar links. If they haven’t been touched in 133k miles, I’m willing to bet they’re shot. Get under the truck and give a good few jerks and tugs on the sway bar. You shouldn’t get any play at all.
Did you ever find the culprit of this? My truck has started making similar sounds and I have also noticed it gets much worse after car washes. Thank you!
Unfortunately, I never did and I ended up trading the truck in. That seemed way easier than continuing to try to chase down that stupid noise lol.
