Shives
Ok... So I post jacked another and want to start fresh.
2019 Black out 1500 5.7 base audio.
1. Bluetooth sounds so much better then uSB connection... I’m sure others have noticed. I’ve also faded my audio to the front to gain better and louder sound. So, tells me that factory amp is about useless to push the factory speakers. But, I don’t sit in the back seat... And screw them. Lol.
So, my idea is to take the factory sub box... Alpine or HK (both you can buy online cheep with driver, alpine is little over 100 and HK is about 145) And hook it up to the factory system, by means of Alipne aftermarket amp. Or something.
so, has anyone tried this yet!? What did you use? Should be simple enough to hook up the factory sub Via the connections under the driver seat. Get the right plug or LOC. Again, just sub!
If I do decide to amp the interior speakers, I’ll get a PAC unit v.2.
Now, to you that have this sub... Is it dual voice coil!? I have a Alipne KTP-445U that I’m considering running 2 ch and bridge the 1-2 and 3-4 for the sub if dual voice and see how she runs. Or, trade that for a Mono block new in box.
really just want some bottom end and volume. I also feel that onceI lower the bass for the Eq, and allow the sub to push that, should produce some better sound.
hummm... I though I also saw someone was able to get the sub out on the factory deck to control volume for the Aftermarket amp and sub. not the PAC unit with control... sub control fro
Deck. Anyone do this!?
It’s winter, time for audio!
