Check engine lights come on for a multitude of emission related issues. This can happen on any vehicle.
What codes come up when you pull the codes? The codes will guide you, or the service department, to the correct route for eliminating the issue. If you don’t have a code reader, go to Auto Zone or a similar parts place and they’ll pull the codes for free and clear the codes.
I had a CEL at about 2900 miles from a misfire. The dealership flashed the firmware and it went away. It hasn't come back in 1k miles so fingers crossed.
Gas mileage improved and it stopped hunting up and down through the RPM on cold start.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
