Carpet soaking wet on driver side
Tysan2c12
I have a 2019 Dodge Ram limited and I went to change my floor mats out and on my driver side the floor was soaking wet and when I pulled the carpet up it was soaking wet all the way up past the gas pedals and up even further. Help where can it be leaking?
jdmartin
Southeast
Some people had a problem with the seam behind the fender and/or on the firewall leaking. I had this problem once (not as bad as you describe) and it turned out to be the door drain was backing up and overflowing when my truck was parked facing downhill and slanted towards the driver's side, and the bottom seal was holding the water in.
SD Rebel
San Diego, CA
As mentioned, it could be a seam in the floor, but based on the amount of water, it' sounds like one of the drains is either stuffed up or disconnected. Open your driver's door, you should be able to work out where the drain tube between the opening of the door where it hinges.
GerryS
Lake Villa, Illinois
Look at the seam in the video.
Gerry
Tysan2c12
Look at the
Gerry
Thank you for the video! Was your carpet wet all the way up past the gas pedals also?
