Cargo light flicker
Kzink
I recently installed led strip lights in the bed of my truck. I tapped into the cargo light tan wire as my 12v+ source and switched my cargo lights to LED’s. Now I’ve noticed my cargo lights work intermittently. Does anything need to be changed in the bcm to tell the truck I’ve swapped to leds or is it the wiring causing my issue?
No, there isn't a setting in the BCM for that.
Some bulbs just won't work in the 3rd brake bed light. I've had good luck in 3 trucks with some from Amazon. Search my threads for my latest build for the link.
