Car Play
piening2150
Not from the factory. There is an aftermarket solution that a lot of people on this forum use.
UnloosedChewtoy
5thGenRams Supporter
South Dakota
What @piening2150 said. Unless you plug in an aftermarket gizmo, its wired Apple CarPlay or Android Auto, not wireless. Wireless Apple CarPlay/Android Auto is coming supposedly with UConnect 5 on the 2022s.
Scram1500
My inlaws just got a Limited Pacifica with UConnect 5. Didn't spend that much time with it, but definitely more advanced than 4. I will try and check out wireless Carplay this weekend
Majortom
I use the the carplay2air dongle with great success. However, I do wish it wouldn‘t switch from the previous music (HD radio or XM) to CarPlay music player each time you restart. There may be a setting, but I haven’t bothered to look into it...
SpeedyV
Ram Connoisseur
Fort Worth, Texas
Mine stays on SiriusXM unless I've been playing media on my phone through another source when I jump into the truck. Also, if you pull up apps that have embedded media (e.g. Facebook) while connected to the truck, you can expect the source to change in the truck too.
Majortom
Appreciate the tip. I often have my player up in background. My not be actively using it, but because it’s not closed, that may be why...
Scram1500
Wireless Carplay works pretty seemlessly on the older Galaxy that I used. Carplay is the same as it is with Uconnect 4 (on the surface) so I moved on to Uconnect 5 itself. I was a bit overwhelmed buy the menus and sub menus in 5. You could waste an afternoon customizing your layout adding apps and shortcuts to the homescreen. For example I think you can create a shortcut for the ventilated seat instead of having to delve into the climate control menu, or a navigation shortcut like home or work
