can i safely remove the anc module under the seat?
darkmage1991
as the title says is it safe for me to do so? as in it wont set a warning light or mess with anything else? i want to do this so i can place my 8 channel amp under the driver seat as my sub amp pretty much takes all the room up behind the seat(only can use the passenger side behind seat due to the etorque battery)
And it should be said i have an aftermarket headunit/stereo so the anc module is already not being used as i have my own speaker wires ran to the new aftermarket speakers.
Alter Ego Trip
I stuffed dual audison surfboards behind mine with etorque. You sure it won't fit back there? Much easier as you already have power/ground back there.
