Mattyhooks
- Dec 31, 2019
Good news!
In preparation to take my truck to the dealer, I was removing the Security Gateway Bypass Harness needed to run AlfaOBD.
When my truck was off, I pressed the EPB Switch just for the sake of it. And sure enough, I could hear the actuators engaging. I said whatever, and proceeded to remove the harness.
It's a very tight space, and I had some trouble getting the electrical connectors out of the CAN blocks. I decided to disconnect the CAN blocks so I could get my hands and tool in and remove the clips.
After disconnecting the CAN blocks, removing the harness and putting it all back together, guess what? No more lights on the dash and the EPB operates normally. I have not reinstalled the harness and ran AlfaOBD for codes yet. And honestly, I probably won't unless more lights come on.
I am not sure what actually fixed the problem. Was it me activating the EPB switch when the truck was off, which tricked the system with one of those perfect situations. Or did disconnecting/reconnecting the CAN blocks reset the system. It also makes me wonder did I even need to purchase AlfaOBD and associated harness?
Either way, I do not recommend disconnecting/reconnecting the CAN blocks. I only did this because I had an appointment for service with the dealer the same day, and why not right.
I hope all this helps the next person...
