Cabin air noise shows up, then disappears
Denny Crane
Southern CA
Hi All,
My 2019 1500 is usually generally very quiet inside. But on occasion (maybe 3-4 times an hour on long drives) it sounds like a rushing air noise pops up, over by the front passenger side dash or post.
After about a minute it just stops suddenly, quiet as can be.
I thought it might be the noise cancellation “recalibrating”, but on a recent trip I notice it coincided with a noticeable air pressure change in my ears. I can’t tell which came first, the noise or the pressure change.
Any ideas?
greenlawnracing
Mine does it as well. There is a thread on it that leaves me to believe there is no known solution. Please let me know if you learn otherwise
BigHerm611
Baton Rouge LA
I have that same issue as well. Haven’t brought it in, but been checking online sources for solutions. So far I haven’t come across any.
XmikeX
Mark down one more with the same occurrence going on. I thought it was wind outside but it happened at low speeds and noticed it sounded like a loud whoosh of air for 5/10 seconds then silence.
Sascwatch
I also have the same issue, but it didn’t start until I had a hvac software update done on my truck that “fixed” an issue with the blend doors causing poor ac performance.
I also have an issue where the ac compressor will turn on randomly even if the cabin temps are set higher than outside temps which cause extremely cold air to come out of the vents for a minute or two. Adjusting the temp up doesn’t stop it either. I think there is a moisture sensor in the cab and it’s trying to dry out the air but I’m not sure.
