Brighter DRL
Killroy
Can/ how do you make the DRLs brighter on the 2021 1500 Laramie?
Uconnect only has on/off.
Not buying new headlights.
Buy different lights cause nothing else you can do.
I believe the DRLs are the low-beam lamps at a reduced brightness. I think you are asking about increasing the brightness of the brow lighting. The first question I have is how bright can the brow lighting safely get. I've seen different brightness levels of brow lighting on RAMs, I always assumed they were different model years. My 2022 brow lamps are brighter than the early model years but could stand a little more brightness.
Is there a setting that AlfaOBD can change? If not, it may be possible to make a relay circuit that is triggered by the brow lighting circuit but routes battery voltage to the brow lamps.
yea, the strips at the top and bottom are not the DRL's, they are accent lighting. They are dim enough that they don't have to turn off when the turn signal is on like if it was a true DRL.
I had read somewhere that drl’s are usually set for 50% of the low beam headlights. Don't think you can change that.
Yea ok, not the DRLs. The accent light is more dim than the newer models.
My low beams are not my DRLs.
