Brake Change - Torque Specs
raygun9
Hey Everyone,
Just changed the pads and rotors for the first time and everything I can find is saying the caliper bracket bolts should be at 75FT Lbs. The gen4s were ~130ft lbs .. 75 seems pretty weak. Just checking what everyone else is doing.
I also got the brake moan kit direct from Mopar - which also says the bolts should be 75ft lbs.
