WhiteKnight4x4
Is anyone using a borla Pro XS muffler? I love the sound from some of the videos I found. What is the correct part number 40358 or 40359?
So it's not center/offset but offset/offset? How much did the install cost?
Nope. My 40353 is offset/offset. Fit perfectly.The 40353 is center inlet, offset outlet.
Now see I’m the opposite as the Atak is way tooo loud for this cowboy.
Any way you could get a sound clip on here?Had the Borla ProXS 40353 installed yesterday. Left the resonators intact.
I'm happy with the sound note and level. It speaks confidently when it needs to and remains silent when it should. Highly recommended.
I guess you never got that sound clip. Did you ever find one on here or anywhere else with resonators intact?Any way you could get a sound clip on here?
Not sure if that is a center in/offset out or reversed, but the 40353 is offset in/offset out which from my understanding is how our stock setup is and will allow for the easiest install. Good luck let us know how it goes and add vid or sound clip if and when you are able.I ordered the Borla Pro XS 40359, i was told this was the correct fit.
Thanks for the info! What year and model ram do you have. Wondering if the 40353 will fit my 2019 Rebel as I’m seeing mixed reviews online. Thanks!40353!! 3” inlet/3” outlet offset. Just had mine installed.
